Wrong Trans Fluid or not? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #16 of 34 Old 11-27-2012, 07:29 PM
Quoted: 1 Post(s)
I always used Valvoline's red bottle, the "max life" dex/merc, pouring it both in the transmission and the power steering res. with my previous two toyotas and that worked fine.
Maybe I will consider upgrading to the real Toyota fluid for my Avalon... just to be sure.
Toyota Dexron IV then?
98 Avalon XLS @ 155k
twodoorcamry is offline
post #17 of 34 Old 11-27-2012, 10:38 PM
Quoted: 4 Post(s)
Originally Posted by denverdog View Post
sounds like you have a "service manager" who's standing there looking like he's going to wet himself because he can't figure out what they do at his own dealership? sounds like you need to speak to his boss, or find another dealership. even call one long distance and ask someone what atf fluid they use on your year of car.
If Toyota had done their job we'd all be talking about somet5hing else right now.
Robert Mustari is offline
post #18 of 34 Old 11-28-2012, 12:15 AM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 771 Post(s)
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 30k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 351k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #19 of 34 Old 11-28-2012, 04:45 AM
Quoted: 65 Post(s)
Originally Posted by csaxon View Post
All DEXRON®-III licenses expired Jan 1 2007 and will not be renewed. That's why it's getting harder to find Dex III. Fluids sold in the market after that date bearing claims such as “suitable for use in DEXRON®-III applications” or similar wording should be avoided. DEXRON®-VI licensed fluids are fully backward compatible and can be used in all applications covered by earlier DexIII specifications. Dex VI is the replacement.
This is the right answer. On my 99 Avalon, I replaced ATF with Walmart brand Supertech Dex 6. I did a complete replacement via cooler line flush. Took about 11or 12 qts IIRC. The Dex 6 made a huge improvement in shifting even though my old fluid was in very good shape as I did drain/fills on a regular basis. I would not put anything in your trans except genuine licensed Dex 6. Also, do a complete flush through the cooler hose (no commercial flushing machine) to get the other stuff out of there.
artbuc is offline
post #20 of 34 Old 11-28-2012, 09:20 AM
Sir Loin of Beef
Jack Deth's Avatar
Quoted: 1 Post(s)
like art, i also drained and refilled my '99 with walmart supertech dex 6. unlike art, i simply drained the pan and the differential, then refilled. that was a year and a half ago. it shifts better, i have no regrets.
Jack Deth is offline
post #21 of 34 Old 11-28-2012, 09:20 PM
Quoted: 1 Post(s)
If you do the coolant line flush, you'll realize how little you're getting out if you drain the pan or drop the pan and drain. To do the coolant line flush, you need 11-14 qts. And when the new fluid has completely flowed through the system, the color change is extremely abrupt and you will know you have completely flushed, i.e. cycled, the old fluid out.
19Glendale is offline
post #22 of 34 Old 11-29-2012, 03:57 AM
Quoted: 65 Post(s)
Yes, it is a quick transition. I estimated less than 1 qt. Don't forget to drain both ATF sumps (if your car has two) and add the same amount of fresh ATF before you begin the coolant line flush. I removed 2 qts, stopped the engine and added 2 fresh qts. I could have sped up the process by letting the sump run dry but I could not make myself do it even though I knew it would not be a problem to run the trans dry for a couple seconds. Doing a complete flush through the coolant line is so easy it is definitely my preferred way to go.
artbuc is offline
post #23 of 34 Old 11-29-2012, 03:35 PM
Senior TN Member
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Quoted: 4 Post(s)
Dexron III was renamed GM Manual Transmission Fluid and carries p/n 88861800 U.S. (88861801 Canada). Mainly used in Allison machinery but still the genuine dex3.
It worked fine until I fixed it!
csaxon is offline
post #24 of 34 Old 11-29-2012, 05:36 PM
Quoted: 4 Post(s)
Let me get this straight. Are you flushing the trans by opening up the cooler line and allowing the trans to pump itself dry?
post #25 of 34 Old 11-30-2012, 04:14 AM
Quoted: 65 Post(s)
No, I did not allow the sump to run dry. I did 2 qt intervals. But, you can not harm the trans by running it dry if you want to speed up the process. You could let the trans pump until you start to see bubbles. Ally the trans parts will be wet and adequately lubed for the 2-3 seconds it will,take you to turn off the car after you see the bubbles.
artbuc is offline
post #26 of 34 Old 11-30-2012, 07:06 AM
Quoted: 4 Post(s)
I've never heard of anybody doing this before. Sounds a little scary. I'd need a helper to turn ther key as I don't move as fast as I used to.
post #27 of 34 Old 11-30-2012, 10:12 AM
Quoted: 65 Post(s)
I run clear tubing to a receiving container right next to the drivers door so I can watch it fill as I sit behind the wheel and I can anticipate as I approach 2 qts. It would be the same if I pumped until I saw bubbles. Yeah, you don't want to be standing at the front of the car and have to run to turn it off.
artbuc is offline
post #28 of 34 Old 11-30-2012, 11:11 AM
Quoted: 4 Post(s)
How do you know which is the pressure line?
post #29 of 34 Old 11-30-2012, 04:25 PM
Quoted: 65 Post(s)
Feel the lines to see which one is hotter - easy to tell the difference. I disconnected where the rubber line from the radiator cooler connects to the metal line going back to the trans. Very easy access. If you search, you will find many posts & pics n how to do this.
artbuc is offline
post #30 of 34 Old 11-30-2012, 04:44 PM
Quoted: 4 Post(s)
That's very interesting. I wonder if the dealer mechanics do this when nobody's looking.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
« Back
