Outside Temperature Display Not Working? - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #1 of 11 Old 07-13-2009, 01:00 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question Outside Temperature Display Not Working?
so the display that is in the car that tells you what the temp is outside is not working. Been like this for couple days now.
At first it will go completely blank, then it will have --. The yesterday it was working again and now today it was blank again
Anyone have any idea what is going on? Where is the sending unit located?
Hope to find a resolution please
95AVALON_GUY is offline
The Following User Says Thank You to 95AVALON_GUY For This Useful Post:
engineer20 (01-04-2016)
post #2 of 11 Old 07-13-2009, 11:20 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Anyone??????
post #3 of 11 Old 07-13-2009, 11:26 PM
Chunkywolf's Avatar
Quoted: 2 Post(s)
I have no idea on how it works mostly, but i do know that the temp control unit behind the HVAC knobs is the computer that calculates it, the display up top doesn't do much else but show it. You may want to just unplug the HVAC section for a few minutes and plug it back in.
Black 95 Avalon XLS 245k
2015 Cascadia DD15 225k
Chunkywolf is offline
post #4 of 11 Old 07-16-2009, 01:26 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I can try to umplug it.. But i thought that by the front bumper was some sort of sensor with a sending unit?
How can the computer INSIDE the car show the temp that is being displayed on the OUTSIDE of the car??
post #5 of 11 Old 07-16-2009, 09:31 AM
Chunkywolf's Avatar
Quoted: 2 Post(s)
From what I understand, there are 2 or 3 temperature sensors that are then averaged to give you the outside temp. I haven't checked, but that's what I heard.
Also, the temperature is processed by the HVAC computer. I know this, because when I unplugged my HVAC unit to replace the lights in it, my temp display read -4 for an hour, and the heat was blasting. this may be different on manual HVAC though
post #6 of 11 Old 07-16-2009, 05:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i wonder if the bulb itself when out???? But i will try to unplug and see if it fixes it...
post #7 of 11 Old 07-17-2009, 04:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Today the temp decided to work I still have not taken the wiring harness out from behind the HVAC controls...
When i was getting closer to home the temp went from 69* ---> - - ---> to a blank screen again....
post #8 of 11 Old 07-24-2009, 03:00 PM
Quoted: 0 Post(s)
I don't have an answer for you, but I am subscribing to the thread because my wifes car has the exact same problem. The sensor that sends the temp signal is down at the bottom of the bumper. It kind looks like a black deer horn. I replaced my wifes with one from the junkyard (could have been good or bad I don't know) and it did not change anything. It still shows "--" Please post back if you figure it out and I will do the same.
cardana24 is offline
post #9 of 11 Old 07-25-2009, 04:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I saw that same sensor on the car that you are talking about. Does that send the info to the inside of the car? I tried to get the sensor off, but that thing is stuck on there lol. I will have to try it again another day to get it off maybe spray it with some dielectrical grease.
I washe my car yesterday, and i'll be damned it is working right now
I dunno what to tell you...
post #10 of 11 Old 01-04-2016, 09:53 AM
Quoted: 183 Post(s)
was wondering the same. my 03 camry temp sensor quit working a few years ago. How do you address and fix that? Thanks.
2003 Toyota Camry 4 cyl. 2AZ-FE
engineer20 is offline
post #11 of 11 Old 01-04-2016, 12:07 PM
2002 Ford Focus SE
TigerHeli's Avatar
Quoted: 1969 Post(s)
It might be similar to the clock issue with the bad solder joints, but I am basically guessing here ...
2016 Hyundai Accent, 10K miles - Toyota Friend ...
TigerHeli is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
Back
