Right Turning (Tie Rod?) Noise?? - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #1 of 3 Old 10-08-2009, 01:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
When I do a sharp slow (or fast) right turn with my 96 avalon, i hear a low knocking noise on the RF tire area. I bought 4 new tires yesterday. they said my tie rod end is STARTING to wearing out, but no need to change or replace it. Is that true? The noise is annoying. and it is my wife car, just want to be sure. Could anyone give me some idea? should I take it to check by others? Thank you.
geocitizen is offline
post #2 of 3 Old 10-09-2009, 12:54 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 664 Post(s)
Most often, a knocking or clicking noise when turning sharply is from worn out CV joints on the drive axles. Making noise when turning right means it's the driver's-side axle.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
post #3 of 3 Old 12-08-2009, 08:38 PM
Quoted: 0 Post(s)
I had an awful noise in my 97 Avalon when I turned sharp right at low speed. I had severe tire wear issues on the outside edges from slop in the front end suspension. I replaced tie-rod ends and struts at the same time and the noise disappeared. I believe the tire was rubbing something, but never determined exactly what caused the noise.
Did your old tires have unusual wear patterns? Watch your new tires for unusual wear.
csyork is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
Back
