Antifreeze/Coolant question - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #1 of 32 Old 08-30-2011, 09:49 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I know Toyota's and Honda's can be sensitive to the coolant added as far as corrosion goes. I've also heard that even if an aftermarket antifreeze says "safe in all systems" or something to that effect, that it may not necessarily be the case. Does anyone know if something like the Penzoil high mileage premixed is acceptable for a GEN1 Avalon system. Thank you.
19Glendale is offline
post #2 of 32 Old 08-30-2011, 08:29 PM
Quoted: 0 Post(s)
All my cars use Walmart concentrated antifreeze never a problem.
turbofrank@verizon is offline
post #3 of 32 Old 08-30-2011, 08:55 PM
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Quoted: 240 Post(s)
Mixing coolant is not as big of a problem as it once was. I recommend using whatever coolant you like, but replacing all of it with the same kind. Then you can keep a little of it around for topping off as needed.
03 Camry - 09 XB - 07 GMC Sierra - 14 Accord Sport
Zembonez is offline
post #4 of 32 Old 08-30-2011, 10:04 PM
I wrench, therefore I am!
Quoted: 0 Post(s)
A gallon of Toyota red will set you back, say $25. A gallon of the cheapest, at least $10. Good for 2 years.
Why risk it? The red is an excellent product. The inside of the cooling system will be like new for the life of the car.
TedL is offline
post #5 of 32 Old 08-31-2011, 04:07 PM
Banned
Quoted: 0 Post(s)
if you buy a gallon of "the cheapest" you will receive a gallon of ethylene glycol. if you buy a gall on "the red," what do you get?
BonzoGonzo is offline
post #6 of 32 Old 08-31-2011, 04:16 PM
Quoted: 0 Post(s)
Huh???????????????????????
TedL is offline
The Following User Says Thank You to TedL For This Useful Post:
pmesfun (08-31-2011)
post #7 of 32 Old 08-31-2011, 06:06 PM
Senior TN Member
Quoted: 237 Post(s)
Toyota Red comes concentrated so it isn't really expensive. Once you mix it with distilled water you get 2 gallons of coolant for $17-24, depending on how much you can get it for.
pmesfun is offline
post #8 of 32 Old 08-31-2011, 09:31 PM
Banned
Quoted: 0 Post(s)
rofl
hopeless....
post #9 of 32 Old 08-31-2011, 10:00 PM
Senior TN Member
Quoted: 237 Post(s)
rofl
hopeless....
likewise
pmesfun is offline
post #10 of 32 Old 09-01-2011, 06:47 AM
Quoted: 65 Post(s)
There is ample information out there explaining the chemistry of various coolants. Yes, the main ingrediant is EG which protects against freezing and boiling. However, if you add only EG and water (even demineralized water), your engine block and radiator would not last very long. Your inference that all coolants are equal because they all contain EG is totally incorrect.
Toyota red is one of the best coolants available. I would not cheap out on coolant.
artbuc is offline
post #11 of 32 Old 09-01-2011, 07:05 AM
Banned
Quoted: 0 Post(s)
sooo.... after about 50 years of driving, and doing 98% of the work my vehicles needed, you're telling me that WATER in my radiator has the potential to harm my car?
if so, what has changed? radiators? engine blocks? water?
one of these days you guys will figure out that being a book-a-holic makes you a SUCKER. the people that write those books put stuff in there that MAKES THEM MONEY...
GOOD MORNING!
post #12 of 32 Old 09-01-2011, 07:41 AM
Quoted: 0 Post(s)
Interesting rhetorical technique. Put words into someone else's mouth, then belittle them for having said what they didn't really say!
Contrary to your assertions, the OM's for the three Toys in my family are very good about specifying generic fluids for oil, P/S, brake and ATF. But not coolant.
I use Supertech oil and ATF, and stock up on Wearever brake fluid and brake cleaner when Advance has its BOGO in January. But I use Toyota red coolant because it is an excellent product which meets the design specs of the vehicle. I would use it if I had to pay $50 per gal. The last two jugs I got for under $12 apiece.
Sometimes "the man" speaks the truth, so I stop, listen and think, rather than reflexively dismissing manufacturer's recommendations. If you want to read flat out untruths about coolant, go to the manufacturer's site for Peak and read what they say about the "old green" stuff they sell. "Universal". "Meets or exceeds all".
TedL is offline
post #13 of 32 Old 09-01-2011, 09:20 AM
Quoted: 0 Post(s)
What's the difference between the Toyota red and standard antifreeze other than Toyota is red and costs a lot more?
By the way i've been running 50/50 standard antifreeze in my two first 4 runners for 10 years, less build up in the radiator and red mess when one of the heater hoses leak.
sleepless_slc is offline
post #14 of 32 Old 09-01-2011, 09:22 AM
Quoted: 0 Post(s)
Less money in you wallet
post #15 of 32 Old 09-01-2011, 09:24 AM
Zembonez's Avatar
Quoted: 240 Post(s)
Coolant is a lot lot like oil. Everybody has an opinion and everybody is convinced they are right.
If changed on a regular schedule, and mixed properly, any commercially available coolant will do the job without harming the vehicle.
Zembonez is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
Tags
antifreeze , coolant
User Tag List
Linear Mode Linear Mode
Back
