98 ignition lock cylinder replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #1 of 5 Old 02-10-2012, 11:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi,
My ignition decided that it would no longer accept any of my keys. From what I understand, it may a problem with the ignition lock cylinder. Does this seem right? My question has to do with what kind of hassle it is to replace on my own, especially if the car has an immobilizer (which I believe it does). I suspect I can't just buy a new lock cylinder and slip it in. Can anybody offer any guidance on this, or direct me to a thread that has already (i've searched extensively, but can't seem to find any information on the added difficulty of an immobilizer). Thanks in advance!
king0913 is offline
post #2 of 5 Old 02-11-2012, 05:20 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 880 Post(s)
Before you go to the trouble of replacing things, are the keys in good condition?... not worn? If they're all worn to some degree, you might try a new key. A dealership can make a new key given the VIN. I did that a while back for my Avy. Cost wasn't too bad; around $10.
Sorry, I can't answer your questions regarding the immobilizer.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 32k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 354k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
post #3 of 5 Old 02-11-2012, 05:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
One of the keys is very worn, but my other master key has not been used at all in the last 5 years, and I don't think it was used very much before then either. I would love for that to be the problem, but based on just looking at the keys, it seems a little doubtful. Thanks for the advice though!
king0913 is offline
post #4 of 5 Old 02-12-2012, 06:40 AM
Quoted: 0 Post(s)
Try some powdered graphite before springing for a new cylinder replacement. Worth a shot for $2.
fourwheeler is offline
post #5 of 5 Old 02-13-2012, 10:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Well, we pulled the ignition switch off the back and decided that I could just use that workaround (screwdriver to start, key in ignition, praying the key doesn't move and lock the steering wheel while I'm driving) until I could get it in and have the cylinder fixed. While we were testing ways to get the key to not move, the key/ignition cylinder decided that it would work again and turn past ACC. Before, it wouldn't even turn all the way to ACC. Removing the switch shouldn't have had any effect on the workings of the cylinder (and the cylinder was still 'stuck' for awhile after we had taken everything apart). I'm not sure what happened, but once it was working, we put a little graphite in just to make sure that it stays lubed and hopefully it won't be a problem anymore.
king0913 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
Tags
ignition , key
User Tag List
Linear Mode Linear Mode
Back
