Re: what is the spark plug order on a 91 toyota corolla
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:99030$4577a0c7$47c2b532$1938@msgid.meganewsservers.com...[color=blue]
> "Learning Richard" <learningrichard@gmail.com> wrote in message
> news:1165457553.493564.11970@n67g2000cwd.googlegroups.com...[color=green]
>> J wrote:[color=darkred]
>>> news:f33fa$4576fd7a$44a4a10d$27032@msgid.meganewsservers.com...
>>> > "J" <J@j.net> wrote in message news:doCdh.1064$4p2.424@trndny07...
>>> >> It's from left to right 1,2,3,4 correct?
>>> >> I'm speaking of the plug wire order from the dist cap in case it's
>>> >> not
>>> >> evident.
>>> >> thanks
>>> > As you are facing the engine compartment, the cylinder numbers, from
>>> > left
>>> > to right, are 1,2,3, and 4.
>>> > If you are talking about ignition firing order, then that is
>>> > incorrect.
>>> > The correct firing order will be 1-3-4-2 or possible 1-2-4-3.
>>> > Ray O
>>> > (correct punctuation to reply)
>>> I'm hooking up the spark plug wires from a new dist cap and I'm just
>>> double
>>> checking the order as 1,2,3,4 left to right. I installed the new cap and
>>> the
>>> car won't fire at all and I put the old cap on and the car idles fine
>>> but
>>> bucks wildly and will stall out if I attempt to drive it.[/color]
>> Did you have to force the wires on (I mean, stretch them, etc). The
>> wires should fit snug and with little effort if you have them all
>> hooked up correctly. Without seeing it I'd imagine all of the wires
>> are of different lengths.
>>[/color]
> No self-respecting engineer would design an engine with a firing order of
> 1-2-3-4 because the power pulses would be too uneven.[/color]
I have a commodore with a buick based V6 in it that has a 6-1-2-3-4-5 firing
order, i'm sure somewhere in the the world is a 1-2-3-4 firing order.
[color=blue]
> Ray O
>[/color]
