Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - illumination wire
View Single Post
Old 06-10-2003, 05:12 PM   #3 (permalink)
mach_y
View mach_y's Photo Gallery
actually, the illum wire on most decks gives the ability to dim the radio in the same way your dash is dimmed. It all depends on what type of signal your illum wire is expecting to see, and what you car uses. Some cars use a drain to ground, others a positive connection. It can be a serious pain to figure out which it is and where to tap in to make it work right. Putting on the parking brake lights will dim it (if it is the correct polarity) when they are on so at least it does something though.
mach_y is offline   Reply With Quote
