Re: 95 Taco Engine "sucking noise"
Steven Zeuner wrote:[color=blue]
> Hi folks, don't know a ton about trucks but i've owned the tacoma since 1995
> and never heard this noise before. It only sounds like its sucking some air
> under acceleration. You can feather the gas on and off and hear the engine
> "suck air" when the accelerator is pressed. I tried to narrow it down.
> Sounds like its under the plenum or around the back right side.
> Any ideas?
> Thanks
>[/color]
I have a 96 Tacoma and mine started something similar recently. It
started the same time that I cleaned my mass airflow sensor. After
doing a few things to diagnose, it sounds like it's coming from the
catalytic converter. I believe that something is broken inside the cat
and that is where the noise is coming from. As to why it started after
cleaning the mass airflow sensor... Maybe there is more airflow so the
sound is more pronounced. The sucking noise is not always there. The
cat also rattles quite a bit but I'm not sure if that's normal. Very
weird...
Dante
