Avalon Intake Q, Flipside help? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-20-2002, 03:55 PM   #1 (permalink)
View AznFiend's Photo Gallery
Hey,
I got an intake for my Avalon, 99'. It fit fine just I think the MAS is confused. The check engine light comes on, turns off when it's really cold. And when I squeal the tires with trac off, it turns on and stays on, even if I try to turn that ish off. I tried resetting the ECU, changed the oil, checked the filter to see if it was dirty, but nothing helped. Flipside you have an Avalon, and you got an intake for it too, did you have problems like this? Is it cause the filter lets in too much air for the ECU to understand? Should I go and buy a K&N cone filter? When in safety mode, it feels slower, but it feels smoother accelerating. I dont like it. Help?
AznFiend is offline   Reply With Quote
Old 03-31-2005, 05:19 PM   #2 (permalink)
View 2000AVALON's Photo Gallery
Make a heat shield to black the hot engine air from going into the intake. Also disconnect your battery for 15 mins to reset the ecu.
2000AVALON is offline   Reply With Quote
Old 04-01-2005, 03:26 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
theres no such thing as too much air. you may have damaged your sensor when you installed it... or forgot to fit every host back... did your intake adaptor plate have a square opening?
terrastrife is offline   Reply With Quote
Old 04-05-2005, 10:47 PM   #4 (permalink)
View Tran's Photo Gallery
were u get tha intake from?tryn to find one for my avalon 99. Ill ask my friend wat the problem is with your car
Tran is offline   Reply With Quote
Old 04-07-2005, 01:41 PM   #5 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
disconnect the battery!
You'll like being blown
Bunthy is offline   Reply With Quote
Old 04-22-2005, 06:55 PM   #6 (permalink)
Toyota Lexus Scion Guru
View Flipside909 [SC³]'s Photo Gallery
Wow this thread is old. 3 years old!
If the light comes back on, that CEL it's throwing up is definitely emissions system related. Most likely your EGR Valve Modulator is probably bad. You should have the code read and checked out.
ClubLexus Editor/Events Coordinator
GRS191
Flipside909 [SC³] is offline   Reply With Quote
Old 04-23-2005, 01:15 AM   #7 (permalink)
can u tell me where u got that intake????????
