I have 2 issues with my 2001 Avalon with 132,000 miles:
1. Exactly what will correct my check engine light with a MIL code P1135, "manufacturer controlled fuel air mixture"? I have replaced the O2 sensors, so that's not it. It's not a California car.
2. Just did a brake job. New front/rear pads and machined all 4 rotors. Bled brakes, new fluid. Replaced guts to master cylinder with factory M.S. rebuild kit. My brakes should be perfect - but they are not. Pedal is not stellar, but does not feel like air (bled them heavily). No hard pedal, like I'm using the backup system from the master cyl instead of the primary system. I can't make the brakes lock up if that tells you anything. I have checked everything, and I feel like I'm a pretty accomplished (amateur) mechanic. So what the heck am I doing wrong? I did not rebuild any wheel cylinders.
