Heat and A/C?
Today I had a car audio shop install an XM radio in my wife's 2000 Avalon XL. I gave them the Vehicle Specific Mount which they installed on the right side of the console. The A/C worked fine before the installation. After the install, the A/C did not blow very cold, even on the coldest setting. The compressor is running, and the high side tube is hot while the suction side is chilled. I turned the A/C off and the air became quite hot. It is as if the heater is on as well as the A/C. The A/C can't overcome the heat added by the heater.
Is this syptom just coincidence, or is it possible that the XM installer crossed up a wire or left something loose that would cause both A/C and heat to run simultaneously?
Thanks for your advice,
David Penz
P.S. By the way, the climate control is the manual type, with dual heat/cool knobs, not the auto version.
