Originally Posted by djbleach
Put 18" rims and tires on 2001 Avalon xl. Can't seem to get them balanced and not virbrate? I've been back 4 times. They have balanced/ rebalanced and even put hub centric rings on. I don't know what to do?
I'm thinking of taking the car and getting the tires "road forced balanced" but was told it would cost $85 bucks.
Has anybody else had similar problems? If so how did you fix the problems.
And you're sure the bolt pattern is 5x114.3 on these wheels and not 5x115? Using wheels with the wrong bolt pattern is becoming more of a problem all the time now.
And are you sure the right lug nuts are being used? The wrong lug nuts can even have the right thread size but with the wrong seat and cause vibration because the wheel never seats properly.
I'm sure you've already checked to see that the torque on every lug bolt is the same and not too high or too low...
Other than hubcentric rings, those are the only other things to look for that I can think of...
Oh, does the vibration occur all the time or only when the tires are cold?
