2000 Avalon factory sub woofer rattle fix? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-20-2007, 09:07 AM   #1 (permalink)
View BajaMike's Photo Gallery
Hi all. Newbie & first thread. Nice site. Q: Any advice/help with the annoying rattle of the factory sub woffer rattle? I've tried tightening all screws & conncections and cover. Still get more vibrations w/little volume to it.
Suggestions-advice.
Love the car. Had it (2) months now. Best car purchase.
BajaMike is offline   Reply With Quote
Old 12-20-2007, 08:44 PM   #2 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
welcome Mike! and join the crowd.... just about everyone i've talked to has a blown rear sub....lol this speaker is actually an 8 inch woofer and not really a sub. dealers want at least 150.00 for this speaker...i've been watching ebay and other places for over a year... some just put a good sub in the trunk. the best fix in the meantime is to open the trunk...look up under the rear deck...take a pair of wire cutters and cut the wires. this way you can crank some volume out of the rest of the speakers without the sub rattling.
silverxls is offline   Reply With Quote
Old 12-24-2007, 08:34 AM   #3 (permalink)
View jef400dread's Photo Gallery
Hey Mike, i had the same problem but took it one step further. I disconnected the wires and removed the speaker all together. Toyota quoted me $250 for replacing it. I talked to my local stereo shop about replacing it with a "free air" subwoofer (older type of subs that sit on the rear dash/panel and use the trunk as the box) but no one makes those any more. So I bought a 10" SAS amplified bazooka tube for about $200 installed. It sounds great too.
jef400dread is offline   Reply With Quote
Old 12-29-2007, 05:38 AM   #4 (permalink)
When replacing w/the 10" SAS, were you able to use the existing factory wiring or replace the factory woofer wiring? Also, did you have to purchase an amp to run the woofer you purchased?
Can you provide a link of what you bought and where to buy on line?
Old 01-02-2008, 09:04 AM   #5 (permalink)
im pretty sure the shop did not use factory wiring, i doubt it would reach off the back dash. i did not need an additional amp, bazooka makes both a 100 watt and 200 watt version, i think mine i the 100 watt, which in addition to the aftermarket HD radio putting out 4 x 20, there’s plenty of bass. The shop even advised me that one powered sub, could adequately power 2 subs
heres a link to the tube.
http://www.crutchfield.com/App/Produ...rch=sas&tp=114
heres a link to the head unit
http://www.crutchfield.com/App/Produ...KDHDR1&tp=5684
If you don't have any experience with car stereo installation, id recommend taking it to a local shop, this type of install should cost less than $100 and many headaches if you dont know what you're doing.
Old 01-02-2008, 02:55 PM   #6 (permalink)
Thanks.
Old 04-13-2008, 11:03 AM   #7 (permalink)
The Spirited Driver
View avalonshoe's Photo Gallery
sell me your blown sub =)
buy these, i have one in my car http://cgi.ebay.com/8-INCH-PIONEER-O...2em118Q2el1247
avalonshoe is offline   Reply With Quote
Old 04-14-2008, 10:38 AM   #8 (permalink)
View kegunder's Photo Gallery
There has been threads which discuss repairing these speakers. I'd like to repair my own 2000 XLS speaker.
Can anyone tell me what the foam dimensions need to be? Is it a flat or sloped inside edge. As an example, see http://www.newfoam.com/kits.asp
kegunder is offline   Reply With Quote
Old 04-14-2008, 12:12 PM   #9 (permalink)
Thanks avalonshoe!
Just logged onto ebay and bought one. Did you have to modify or do anything differently? Just take the old out, wire the new in?
Old 04-14-2008, 04:12 PM   #10 (permalink)
The Spirited Driver
no real modifications, if u buy the foam kit, just buy the 8" diameter kit.
if u buy another oem-like replacement the woofer, all u have to do is match up the red (+) and black (-)wire on the woofer and connect them. 8" should fit well onto the black frame that holds the jbl woofer and use dampeners between the screw and black frame..
if u want you could rig the wire harness/adapter (female or male i forgot) from the blown woofer to the new woofer and plug it in to the car harness.
Old 04-16-2008, 10:41 PM   #11 (permalink)
View TheBigKahuna's Photo Gallery
Just bought an '00 Avalon, and this was about the only thing we could find wrong with the car...the sub rattles. I really need to fix this.
TheBigKahuna is offline   Reply With Quote
Old 04-16-2008, 10:51 PM   #12 (permalink)
The Spirited Driver
it wont matter if u buy a new factory JBL replacement sub, it WILL happen again. Replace it with a different OEM type sub.
Old 04-17-2008, 01:04 PM   #13 (permalink)
What's the recommended wattage and OHM for a replacement?
Old 04-17-2008, 05:10 PM   #14 (permalink)
The Spirited Driver
~27W @ 3.7ohms
its hard to find a sub within that range. u can use a sub thats 4ohms and maybe a little higher wattage. make sure u look for a freeair sub though.
Old 04-19-2008, 10:18 AM   #15 (permalink)
View twoavalons's Photo Gallery
eBay sub works great...
I replaced my factory 8" with an aftermarket sub like the one in the Pioneer link above. The swap was simple. A tiny bit of solder holds the new clips just like factory. I didn't even have to drill new holes. Unless you are adding an amp to power your new sub, save your $100. I am no audiophile but I do like my tunes loud sometimes (hard-of-hearing from playing it loud in my teens). My 2000 Avalon XLS stereo is one reason my wife and I race to see who gets to drive it.
I just replaced the factory cassette in my daughter's 97 Avalon with a nice Clarion CD/USB/iPod unit from Crutchfield. My plan is to add the above mentioned sub in the factory position since hers had no factory sub. She is less concerned about bass than I am but I do have to drive the car sometimes!
Best to you!
2000 Avalon XLS 240k
1999 4Runner 183k
2001 Accord 146k
2003 Odyssey 213k
twoavalons is offline   Reply With Quote
1995 avalon factory stereo runriver 1st Generation (1995-1999) 12 04-06-2011 02:26 AM
97 Avalon XLS Stereo - Compatible Factory Units? emery 1st Generation (1995-1999) 2 10-02-2007 11:29 AM
2000 avalon eckounlmtdest87 2nd Generation (2000-2004) 6 03-27-2004 09:00 PM
