2000 Avalon Flywheel Cover - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-07-2008, 11:12 AM   #1 (permalink)
View superpromustang's Photo Gallery
Hello all, I'm new to this site, I just replaced the tbelt on my dad's 2000 avalon, which involved removing the flywheel cover so I could shove a screwdriver into the hole to keep the engine from rotating while I was removing the crank bolt, however I had to bend the crap out of it to get it out because it bolts to the exhaust bracket, my question is, how in the blue hell do you get it back on without removing the exhaust, and if you do, how to you remove the exhaust? Thanks in advance.
superpromustang is offline   Reply With Quote
Old 01-09-2008, 04:54 PM   #2 (permalink)
View kegunder's Photo Gallery
Sorry, I can't help you. But others may know theres a trick which prevents the need to remove the flywheel cover. Put a breaker bar & socket on the crankshaft bolt. Then engage the starter moter for just bit. The bar will smack against something (hopefully the control arm) and you bolt will be loose. Search the forum for more hints. Try at your own risk.
Tightening the bolt w/o an air powered wrench is another issue though.
kegunder is offline   Reply With Quote
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 6 04-01-2012 09:05 AM
04 Celica GTS Timing Turbo2tom Celica Forum 2 12-18-2007 03:03 AM
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
WTT: 2000 Solara SE V6 for Avalon or Camry ericisbacchus Car parts for trade or wanted parts 0 07-15-2007 10:04 PM
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
