Originally Posted by Jigg007
HIDs go in projectors for reasons, optic reasons. If you put a HID light in a housing designed for halogen bulbs you're going to blind everyone on the road, and the light diffusion is going to be all messed up.
True 99% of the time. I had a Porsche Boxster and the forum had a retrofit for HID's. One member found the proper HID bulb whose gas pod lined up the exact same distance from the reflector as the filament on the standard halogens.
No light "spray" and the pattern stayed the same. Just a lot more bright white light.
The distance from the reflector is the key here........
With that being said.....I'm a fan of the PIAA Xtreme White Plus bulbs. More light, whiter light, plug and play. Just shop for a deal as these can be had for around 50% of the PIAA Website prices. Might run you $150 if you do the low beams (9006), high beams (9005) and fog lights (9006).
