Windshield solvent pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 02-16-2008, 03:15 PM   #1 (permalink)
View ChiTDI's Photo Gallery
Question Windshield solvent pressure
My solvent barely squirts out of the nozzles on my '02. Is there any special trick to cleaning them or the tubes that deliver the fluid to them?
Been below freezing for three weeks here and car repair at zero in a foot of snow has been difficult.
ChiTDI is offline   Reply With Quote
Old 02-22-2008, 11:13 PM   #2 (permalink)
View toyomoho's Photo Gallery
Make sure the fluid is not freezing in the system. You can remove the lines to the nozzles then run the washer and determine if enough fluid is coming out. If Ok, the nozzles are most likely clogged, use a needle to clean them. If not, go back further on the tubing to check for plugged areas. You can remove the tube from the pump and blow them out with air.
Old 02-25-2008, 11:06 AM   #3 (permalink)
Outstanding. Thanks.
Didn't know I could disconnect at the nozzles!
Old 04-25-2008, 04:09 PM   #4 (permalink)
Cleared the plugged hoses and vwallah!!
Toyomoho - YU DA MAN !
Old 04-28-2008, 11:33 AM   #5 (permalink)
The Spirited Driver
View avalonshoe's Photo Gallery
i just stab the nozzle with a needle and fix it.. make sure u the smallest needles, test, then gradually use a bigger needle. i know someone that used the biggest needle and made the nozzle shoot windshield washer fluid over the windshield
avalonshoe is offline   Reply With Quote
Old 04-28-2008, 03:33 PM   #6 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
Isn't that what they are supposed to do?
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
Old 04-28-2008, 03:38 PM   #7 (permalink)
The Spirited Driver
i meant ....and "overshot" the windshield haha
