Which ATF for 01 Avalon? Is differential separately from transmission? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 03-28-2008, 10:20 PM   #1 (permalink)
View car5car's Photo Gallery
DEleted
I
car5car is offline   Reply With Quote
Old 03-30-2008, 09:38 AM   #2 (permalink)
View ChiTDI's Photo Gallery
The ATF spec is DexIII and there sure was a separate drain but NOT a fill plug on my '02.
Thanks to many posters here I got the info that you're asking about. The ATF drain is a 55 Torx and the differential drain is a hex. Don't remember the size. One unit fills the other on my application, but yours maybe different. Look for a fill plug up above the drain area toward the front. They both take ATF in the Avalon. I use Schaeffer's ATF, not because it is T-IV rated, it just shifts really well using it.
ChiTDI is offline   Reply With Quote
Old 03-30-2008, 04:42 PM   #3 (permalink)
Thanks. I called dealer and they said there is a fill plug on top. I found one and used it. There is no way to check fluid level in differential but it looks like they are connected so level is the same. Dealer guy said there is seal and bearing between them.
