'04 Avalon Steering issue Any Suggestions?
While driving today I noticed that the wheel is turning weird. It turns fine for the first 10 degrees, but then there is a resistance like a 'hump' feeling, then it gets easy and then another hump. When I let go at the end of the turn, the wheel doesn't come back to straight(0 degrees) like it normally does without help.
The car has 45,000 miles. I have checked the power steering fluid, it looks fine and is full. I checked under the car for leaking fluid....none.
It isn't 'hard' to turn, but you can tell something isn't right. Any suggestions? Anything I should check?
I do have a full manual set, but can't really find much.
Thanks.
