Toyota charges about 600 for valve adjustment, It is 1 hour job! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 04-09-2008, 06:02 AM   #1 (permalink)
View car5car's Photo Gallery
2 things wear out- cam lobe and shim. If Toyota engineers are smart and I think they are shims are made off softer steel than camshaft so I would expect only shims wear. I think turning shims upside down should do the job unless it was done already. I called dealership, they don't have shims in stock! I have to wait for next day delivery unless I order until 10.30 AM. By the way only front head valves are clicking, I will not do rear valves, no need for intake manifold removal- it shoud take only 30 min. I will have to make tool to hold valve down- no big deal, maybe screwdriver will work fine.
car5car is offline   Reply With Quote
Old 04-09-2008, 06:30 PM   #2 (permalink)
3 exhaust valves had .018; .019;.000 clearance. Supposed to be .010-.014
0 is not good. Hopefully valve is OK. Screwdriver worked fine but I had to buy 3 shims. $20. Good luck!
Old 04-10-2008, 09:35 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
What mileage does this car have? Is the engine original to the car?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-10-2008, 12:58 PM   #4 (permalink)
138K
Old 04-12-2008, 04:55 PM   #5 (permalink)
View TMack409's Photo Gallery
I just checked the lash on my 1996 Avalon with 180K miles. They were all within spec. The reason the dealer doesn't stock them is that under normal use, with regular oil changes, they don't wear.
TMack409 is offline   Reply With Quote
