Left Rear toe adjuster frozen - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 04-09-2008, 04:20 PM   #1 (permalink)
View srfoot's Photo Gallery
I had my tires rotated and a 4 wheel alignment. I was told that the left rear toe adjuster is frozen. It measured at -0.25 degrees. The right is at 0.17 degrees.
Is this a big job to fix and what is involved?
Any help would be appreciated.
The tire place I brought it to does not do repairs but will do the alignment free of charge when fixed.
srfoot is offline   Reply With Quote
Old 04-09-2008, 08:07 PM   #2 (permalink)
View toyomoho's Photo Gallery
Look at the suspension under the left rear of car. There are two long rods coming from the center of the frame out to the rear axle carrier. The rear rod is adjustable in length by a turnbuckle type arrangement using threaded rods and a long nut.
The nut may be rusted to the treads. Use something like penetrating oil and or a torch to attempt to free it. There are lock nuts on each side of the turnbuckle nut as such make sure these are loose before attempting to rotate it. The rod is removable by taking out the bolts at each end if required.
If you take the rod apart make sure the length of exposed threads is the same on each end. Take a measurement of overall rod length to be able to reset after freeing the turnbuckle.
Old 04-10-2008, 07:41 PM   #3 (permalink)
Thank you for your response.
I will try this!
Old 02-15-2009, 12:42 PM   #4 (permalink)
Nunzie's Avatar
View Nunzie's Photo Gallery
A few months after I had an alignment I started to notice a clunck sound over bumps. I first thought it was the struts since it has 91k miles. I crawled under the car to find one of the rear tie-rods loose (source of the clunck sound). I can not tighten or loosen it by hand. I could try putting heat to it, but I might just go back to Sear in Burlington MA and have them fix it.
Lexus IS300, 04 Sienna LE, 01 Avalon XLS
(sold) 99 Tacoma TRD ---- 86 SR5 Xtra cab, 35's w/8.5" lift
Nunzie is offline   Reply With Quote
