Originally Posted by avalonshoe
group V could be based off any combination of anything in group I-IV right? how would u know the mix unless its listed on the bottle
A Group V REDLINE syn is unique. It is almost totally man made: From Polyol esters (POEs), which comprise most of it's base stock. It shares nothing with Groups I-IV (except the small additive package which is contained in all oils). FWIW REDLINE contains less of this additive package than all others. In fact, M1's Extended Performance syn has to use lots of additives to achieve that "extended performance".
It's very difficult to ascertain exactly what's in an oil. Lot's of manufacturers want to keep it top secret [and for good reason] - esp at the low end of the spectrum where they are fighting hardest for Joe Six Pack dollars.... a battle that Castrol is mostly winning [due to the cheapening of their formula, which allows for more advertising dollars to be spent].
Not to pick on anyone in particular,
AFAIK, Royal Purple does not publish their exact mix of content in their syn. IIRC Royal Purple is Group IV. But they might have slid backwards to Group III in order to allow for more ad dollars. I've seen more and more of them lately.
You would probably have to write the manufacturer to get the Group number. But trust, me they all have it - some just not so proud of it.
-Group I: Traditional dino motor oils (mineral)
-Group II: Valvoline MaxLife - the only dino oil that meets that standard (that I know of).
-Group III: Castrol syn and their ilk. Highly refined petroleum (mineral oil). Hydrocracked. crap! Most widely available, off the shelf, syns fit this category. The worst of the Castrol syn IMO is the 5W30 /Horrific shear properties under high operating temps. If you absolutely insist on buying and using Castrol syn - use anything but their 5W30. You must change GIII oil every 3K. Period.
-Group IV: The better M1 (extended service) syns and Amsoil and maybe RP
(In the old days, the SAE mandated that in order to be called "synthetic" -
Synthetic base stocks must be Poly-alpha-Olefin [API rated = Group 4].Sadly, however, the SAE dropped the PAO requirement awhile back and Castrol jumped in with their hydrocracked crap and are now get away with calling it "synthetic".) [consumer fraud IMO])
-Group V: Of course - REDLINE (12,000-15,000 mile interval on modern cars). I don't chance it past 10,000 on my 12 year old 1MZ-FE. But even at 10K drain interval, the cost of the REDLINE offsets the cost of three -3K mile oil changes when using dino.
