2001 Alignment Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 05-18-2008, 01:41 PM   #1 (permalink)
View DOT3's Photo Gallery
The alignment on my 2001 is barely within spec but pulls slightly to the right.
Shop says that they can't adjust anymore so they need to drill out the strut mounting bolt or something to give it more room to adjust.
Anybody heard of this?
1999 4runner SR5 4x4 5spd Stock
2007 Tacoma Access Cab 2.7 5spd 4X2 SR5
2001 Avalon XL
DOT3 is offline   Reply With Quote
Old 05-18-2008, 01:59 PM   #2 (permalink)
View toyomoho's Photo Gallery
Was the car in an accident or has it been lowered?
There may be a camber plate for this car which would allow adjustments as the shop is talking about.
Old 05-18-2008, 07:05 PM   #3 (permalink)
No, the car is in pristine condition with 55k miles.
Tell me more about this camber plate.
Thanks
2001 Avalon XL
Old 05-18-2008, 07:22 PM   #4 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Do you have the numbers and tolerances?
If alignment is within spec but you still have a 'slight' pull, the problem is probably with the tires. Drilling holes in the strut tower is not an acceptable solution. Toyota provides plenty of room to adjust alignment geometry with suspension equipment that isn't bent or damaged and tires that are wearing evenly.
Try inspecting the tires for proper inflation and wear first, then rotating to see of the pull changes. Also be mindful of the roads you drive on. Some will send you left, right, or straight ahead depending on the crown.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 05-21-2008, 01:31 PM   #5 (permalink)
View keyboardracer's Photo Gallery
you might need to check the lower control arm bushing is it pop out or not, because if it is loose it might contribute to your misalignment.
keyboardracer is offline   Reply With Quote
Old 05-21-2008, 01:45 PM   #6 (permalink)
Keep the comments coming.
The car has not been wrecked and the tires are < 10,000 miles michelin pilots.
2001 Avalon XL
Old 05-21-2008, 07:22 PM   #7 (permalink)
Qslim's Avatar
Tires can make a car pull regardless of mileage (called a 'radial' pull). If the alignment is within spec, it's within spec. Rotate the tires, it'll help you rule out a variable (assuming you don't have directionals).
-- Get him, boy....
Old 05-24-2008, 11:48 PM   #8 (permalink)
View aznstylez's Photo Gallery
have you or anyone hit the curve or anything with the front tire? put your fingers inbetween the front and the back of the tire. If you can put two fingers in the back of the tire(from sidewall to tire), you should be able to put two fingers in the front of the tire too. If it is not even, than you have a caster problem, I think that is what they call it. If that's the problem, you're gonna have to pull your suspension forward to make it even again. Good luck.
aznstylez is offline   Reply With Quote
Old 06-17-2008, 01:43 PM   #9 (permalink)
Took it to the dealer today and they lined it up fine.
The other shop had trouble with the left front camber at -1.4. The dealer centered it at -0.8.
2001 Avalon XL
Old 06-18-2008, 07:59 PM   #10 (permalink)
View Eurobob's Photo Gallery
radial pull from the tires. Caster is the spec on an alignment that will make the car pull. most cars do not have caster adjustment. check with the shop that looked at the alignment. I say tires are the problem though
Eurobob is offline   Reply With Quote
