2000 xls transmission leak - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 05-26-2008, 09:15 AM   #1 (permalink)
View robdtoyota's Photo Gallery
I have a 2000 with 95,000 miles. I last changed tranny fluid at 90,000 - mechanic used the machine method not the drop pan manual method. I noticed a leak this morning. Fluid is accumulating on the pan just above the oil pan drain plug. Anyone have experience w/ a trans fluid leak? In 30 years, never had a Toyota leak anything. So I have no experience. Thanks - Rob
robdtoyota is offline   Reply With Quote
Old 05-27-2008, 05:48 PM   #2 (permalink)
View toyomoho's Photo Gallery
Make sure it is trans fluid.
Check for leaks at the line connections for the trans fluid cooler, may be a loose hose clamp. Not typical but the hoses may have been disconnected.
The more typical would be trans pan gasket leak.
