Rear Jacking/lifting points 00 Avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 05-27-2008, 08:43 AM   #1 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
Question Rear Jacking/lifting points 00 Avalon
I'm about to rotate my tires and am looking for a spot under the rear to place my floor jack to lift the car and set it on jackstands. The front looks like I can use the crossmember to lift and side rails for the stands, but I'm not sure about the rear of the car. Any Suggestions?
Thanks
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
Old 05-27-2008, 05:44 PM   #2 (permalink)
View toyomoho's Photo Gallery
I usually rotate in the spare, change one tire out a time then rotate the spare out. This keeps 3 tires on the ground at all times.
Old 05-28-2008, 08:03 AM   #3 (permalink)
tr7driver's Avatar
Thanks for the suggestion. Rotating the spare also spreads tire wear and results in longer life for all 5 tires. Unfortunately, my spare doesn’t match the other tires, so I just want to get her up off the ground and do the rotation and give the car a good inspection.
2000 Avalon XLS
Old 06-20-2008, 09:44 PM   #4 (permalink)
View preacherzson's Photo Gallery
Rear Jack point
It's between the rear tires, next to the exhaust pipe. You'll see a bump in the middle of the car- that's your target.
preacherzson is offline   Reply With Quote
Old 06-24-2008, 09:32 AM   #5 (permalink)
tr7driver's Avatar
Thanks for the information. I wasn't sure if the rear center location was stout enough to jack the car.
2000 Avalon XLS
Old 06-25-2008, 06:46 PM   #6 (permalink)
yup, it'll held my Avy. I had my car jacked up 18 inches using that jack point. Makes reaching the calipers/rotors/brakes a snap.
