Bought a 2000 Avalon; blew the subwoofer already. Suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 06-10-2008, 09:10 PM   #1 (permalink)
View meh4's Photo Gallery
Hello all, I'm new to the forums and I bought a 2000 Avalon XLS last week. Its the quietest and smoothest car I have ever driven and the interior is very solid. Though I already blew the rear subwoofer. I did read the thread regarding the fix for the rattle; but I want to know what people have replaced the factory woofer with...? I was just going to drop the 8 inch Infinity reference series subwoofer in and connect it to the factory amplifier. I really don't want to add any after market amplifiers or have any subwoofer boxes in the trunk.
I know that a free air setup isn't recommended by Infinity, but they do say its possible and that the recommended power ratings should be cut in half for free air use. I'm going to assume the JBL stereo doesn't give 100 watts RMS to the rear woofer, so based on my assumption; it'll be fine.
Can anybody share their experiences with replacing the factory subwoofer, and using the factory amp? Does anyone know the sensitivity rating of the factory woofer?
meh4 is offline   Reply With Quote
Old 06-13-2008, 01:37 PM   #2 (permalink)
View Eurobob's Photo Gallery
Double check the impedance on the factory driver and the Infinity that you are going to put in. make sure they match. You will probably be disappointed in the output running free air. power handling is cut in half because there is too much air volume to keep the woofer cone in check. The air in a sealed or ported box acts as a spring to limit the cone movement. I would look at parts express for raw drivers. The is a decent speaker program called WinISD. You can load different woofers with the air volume in your trunk and compare output, cone excursion and so on. Stay away from any woofer that has more than a 4 layer voice coil...6 and 8 layer have a lot of inductance and can ruin the output stage of the amplifier. Good luck
Eurobob is offline   Reply With Quote
Old 06-13-2008, 05:41 PM   #3 (permalink)
Check these out. http://www.partsexpress.com/pe/showd...number=295-480.
http://www.partsexpress.com/pe/showd...number=295-545
Old 06-15-2008, 11:02 AM   #4 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
fix your original speaker. go to www.newfoam.com
silverxls is offline   Reply With Quote
Old 06-15-2008, 09:21 PM   #5 (permalink)
Thanks for the info! Unfortunately my speaker doesn't need to be re foamed. Something else has broke, causing it to make a rattling sound. I have ordered the speaker in the second link that was posted by Eurobob. I have already tried replacing the rear woofer with an 8 inch woofer by MTX that I got from a shady local stereo shop. The results were less than impressive... coulbe be due to lack of proper installation as I was unable to fully seat the speaker in the factory speaker hole, but I took it out and returned it. I hope the speaker I ordered works out, regardless of it's performance - it will stay in the car... I really dislike tearing into the car I just bought less than a month ago.
So in my experience: MTX 8 inch speaker (4 ohm) - No good for factory replacement.
I will let you guys know my experiences with the new speaker when I get a chance to install it.
Old 07-06-2008, 09:07 AM   #6 (permalink)
View Gerald's Photo Gallery
I have that same rattle going on in my wifes 2001 Avvy. Does the rattle mean the sub is blown ???
Gerald is offline   Reply With Quote
Old 08-01-2008, 07:20 PM   #7 (permalink)
silverxls's Avatar
yep gerald, it is prob blown. just about every older avy i have seen this has happened. in lookin at several different cars, i think the problem is the way the speaker is mounted. it fits in a plastic housing, then another piece of plastic fits on top and is bolted down tight. this top piece squeezes the foam flat, and i think it makes it easier for the foam to break around that edge. i re-foamed mine and then did a friends and both sound like new, and for a fraction of the price of the toyota replacement (179 or more)
Old 08-08-2008, 04:24 PM   #8 (permalink)
make sure the cover did not come loose and that is the noise you are hearing. there are a couple of snap tabs that it slides into. my cover has come loose several times and made strange noise, woofer good. take the cover off and listen again. if it still rattles, replace it. it will eventually wear out the voice coil and weld itself to the magnet gap and then you will get no noise and possibly damage the amp because it is now in a dead short.
Old 08-15-2008, 11:46 AM   #9 (permalink)
View jeffgp's Photo Gallery
Recone Them!
del..
jeffgp is offline   Reply With Quote
Old 08-15-2008, 11:48 AM   #10 (permalink)
REFOAM or RECONE THEM!
STOP!
http://www.speakerex.com/speaker_repair.html
AWESOME..... $43.00 to re-FOAM the sub-woofer plus shipping both ways.
ASK for MIKE!
Old 01-19-2012, 02:28 AM   #11 (permalink)
View ZAN986's Photo Gallery
Just replaced blown out stock jbl sub with this http://www.bestbuy.com/site/Kicker+-...cker&cp=1&lp=4
ZAN986 is offline   Reply With Quote
