Rough idle when starting - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 07-06-2008, 06:09 PM   #1 (permalink)
View 20solara02's Photo Gallery
Hi everyone,
My parents just bought a 2002 avalon. It has rough idles and almost dies, sometimes does, when first starting it. If you keep on the gas a little to keep the rpms up it will eventually hold on its own and be fine. once the car is moving it idles and runs fine. Anybody have any clues on what could be the problem?
I was going to change the spark plugs with ngk iridiums, hoping that might help, but i'm not sure if that could be causing the problems. I did pull one plug to look at it and the tip was rather white. There are no CEL on and the car runs strong. It only happens during warm up.
any help would be appreciated
Thanks,
Michael
20solara02 is offline   Reply With Quote
Old 07-07-2008, 09:47 AM   #2 (permalink)
View ChiTDI's Photo Gallery
Manual for reference
Originally Posted by 20solara02 View Post
Hi everyone,
Thanks,
Michael
Get a manual, library or purchase, clean the AIC - air idle control motor and go from there.
ChiTDI is offline   Reply With Quote
Old 07-07-2008, 01:00 PM   #3 (permalink)
View ed_camry's Photo Gallery
rough idle and infrequent shut-offs
I have a similar problem w/ 99 Camry. New spark plugs and new Idle motor didn't help.
Any other possibilities?
Thanks.
Ed.
ed_camry is offline   Reply With Quote
Old 07-08-2008, 01:17 PM   #4 (permalink)
View toyomoho's Photo Gallery
Engine idles rough when cold but OK when hot.
There is a fuel enhancement system that turns on when the coolant is cold. Might be the coolant temp sensor.
Old 07-08-2008, 07:48 PM   #5 (permalink)
View TMack409's Photo Gallery
/\/\/\ What he said, but have you cleaned the throttle body butterfly?
TMack409 is offline   Reply With Quote
Old 07-08-2008, 08:14 PM   #6 (permalink)
infrequent shut offs?
Thanks.
Ed.
Welcome to the club. Rough idle can be AIC or dirty throttle butterfly as stated. Or could be electronic, you could have a bad coil, wire, but the infrequent shut offs? Does the engine just quit? Restart difficult?
Describe what goes on, maybe they're related.
Old 07-15-2008, 02:36 AM   #7 (permalink)
The Spirited Driver
View avalonshoe's Photo Gallery
apart from the idle controller, check the throttle body fins, mine were stuck before due to carbon build up.
avalonshoe is offline   Reply With Quote
Old 07-17-2008, 10:56 AM   #8 (permalink)
ed and solara - what worked?
toyomoho - sorry, I misread and didn't see the cold rough idle. ETC sensor was the right call. Your input is always appreciated.
Old 08-05-2008, 04:51 PM   #9 (permalink)
Good, as new!
Thanks all for contributing.
I ended up at the dialership and they told me that the coolant temp sensor
had a bad spot and as temperature reached let say... 100-110 Deg., the engine would not hold the idle speed and shuts off.
That would also explain why car would not start while the engine is still worm.
