Tranney Hesitation
2001 Avalon- I just finished a MAJOR tune- plugs, adjust valves, timing-kit, waterpump-kit. I also did a COMPLETE pan-removal, cleaning and fluid refill on the tranney. I used the same synthetic fluid I have been running for 52K miles with zero problems.
The engine is running better than when new, no problem with power. But, a while ago, before all this, I started having a problem with the tranney-shift.
The tranney shifts fast, and very tight, no problems. Also, when changed, there were very tiny (normal) particles on the magnets. The fluid was slightly dirty, but not burnt, no bad smell. I have had this car since new, and never abuse the tranney.
The problem is ALL gears shift fast, and very tight, EXCEPT the final top-gear. The engine often climbs to 3000-3400K and hangs there, not shifting into top gear. If I drop OFF the gas (dropping down RPMs/vacuum), the tranney will immediately drop into top gear, fast and smooth, with no hesitation. If I dont, the car will often cruise quite a ways before the tranney finally catches top gear.
I have been "wrenching" on my cars for 30+ years, and I am stumped, although I'll admit I am an engine/brake/suspension guy and know very little about AT's. Any ideas? Why won't top-gear drop in? Why are all the other gears shifting perfectly, fast/smooth, but not the top gear? Any ideas would be appreciated- Wrenchy
