'04 Avalon cold start problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 08-15-2008, 07:59 PM   #1 (permalink)
View hvymetalalchmst's Photo Gallery
Unhappy '04 Avalon cold start problem
hi all,
my 2004 3.0L V6 avalon seems to have problems when starting, especially cold starting (i live in Melbourne, Australia). It comes on and off irregularly. Most days it seems like as if there is no choke whereas sometimes, out of dumb luck, it starts normally.
does anyone else have similar problems, and does anyone know how to fix this?
much appreciated,
rex
edit: hold on, i just found a similar thread. ill check the throttle butterfly, throttle body fins, AIC and coolant temp sensor before i get back
hvymetalalchmst is offline   Reply With Quote
Old 08-19-2008, 02:17 PM   #2 (permalink)
View ChiTDI's Photo Gallery
Welcome to the club, and was it the electronic temperature sensor?
ChiTDI is offline   Reply With Quote
Old 08-21-2008, 03:36 AM   #3 (permalink)
(just to let you all know, although that this isnt exactly my car, its my dad's, but i have to fix it so it becomes my problem, so there was a little loss of info from the first thread, which ive fixed up) - after my dad decided to tell me that the car DOES have the same problem even when hot, i got pretty frustrated that i had already posted my question.
wheres the etc? (if it its connected to the throttle body, more than likely, ive checked and cleaned it with some low pressure compressed air.)
we but i have cleaned the aic, with no improvements.
but sorry for the little misunderstading...maybe this extra bit of info might help?
rex
Old 08-31-2008, 10:24 AM   #4 (permalink)
View redsand's Photo Gallery
hi, this issue occured in my 01 and it was an idle control motor which required replacement; voila problem solved .. i hope that this helps you.
redsand is offline   Reply With Quote
Old 09-02-2008, 06:45 AM   #5 (permalink)
thanks, ill go try that.
thanks everyone!
