Originally Posted by new echo owner
There are bushings for the swaybar that can be replaced if that is the cause. Were you on uneven road surface when it makes the noise? How about going straight over a speed bump?
N.E.O.
Thanks for the reply. yes it makes the noise only on potholes, uneven rough road. If i go straight over a speed bump it dose not make the noise.
though if my windows are down i can hear the hydrolic swish kind of noise from the suspensions when i go over speed bumps depending on how big the bump is, should i be worried about the hydrolic kinda noise it only happens on speed bumps.
Thanks,
