Drivers window - does not roll down 100% - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 09-21-2008, 10:41 PM   #1 (permalink)
Resident Wiseguy
Riick's Avatar
View Riick's Photo Gallery
2nd Generation Drivers window - does not roll down 100%
2000 Avalon. Driver's side window (LF) does not roll down 100%
Stays up by say 1/4" -1/3". I can manually push it down all the way.
I'm guessing the widow regulator is sticking just a little, or maybe slides sticking??
Anyone with experience with sticky power windows with directions/advice ...or should I just ignore it?
Riick is offline   Reply With Quote
Old 09-21-2008, 10:59 PM   #2 (permalink)
just a nobody
Should probably take the door panel off and take a look inside. It is hard to say what is causing your problem but it could also be a sign of maybe something failing or a wiring harness got in the way.
N.E.O.
Old 09-22-2008, 12:31 PM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
Welcome to the club. My 2002 was diagnosed with a bad motor, and a new one was $100+ to replace it. Since I almost always drive with my windows up anyway I said screw it. I use my window so rarely it just isn't worth the time and expense to fix it. Anyway, if it's your motor the repair won't be cheap....
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 09-22-2008, 06:12 PM   #4 (permalink)
View Eurobob's Photo Gallery
that sounds right. the regulator or the motor. the glass could not be in the channel the whole way either. mine makes noise like the glass is loose. I havent looked at it yet, but maybe the channel for the glass is missing a bolt or off a bit. take the panel off and look a bit closer
Eurobob is offline   Reply With Quote
