Belts too tight? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 09-26-2008, 09:14 AM   #1 (permalink)
View eckbrethpj's Photo Gallery
Belts too tight?
I had the timing belt and water pump replaced recently on my 2001 Avalon XLS (175,000 miles) at the Toyota dealer. Now it seems as though the belts are too tight. The engine RPM is lower than beofre the maintenance and the car seems to be dragging. My mileage went from 26 mpg to 21 mpg after the maintenance. Any ideas if this is correct?
eckbrethpj is offline   Reply With Quote
Old 09-26-2008, 09:42 AM   #2 (permalink)
just a nobody
If the cam timing is not aligned properly it will affect the engine the way you had described. Take it back to them and have them recheck their work.
N.E.O.
Old 09-28-2008, 04:36 PM   #3 (permalink)
View aznstylez's Photo Gallery
they didn't redo the timing. take it back to them.
aznstylez is offline   Reply With Quote
Old 09-29-2008, 10:43 AM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
I'd also be wary for how they billed you on the repair. Make sure they didn't double-bill for the water pump removal, which is already included with the timing belt replacement. It always helps to stay on top of repair facilities....
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 09-30-2008, 10:16 AM   #5 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
Are You getting a CEL? When I had my timing belt done on my 2000 av at 105K the car ran fine but after about 10 miles it threw a CEL. The code indicated the cam sensor was off. I took it back to the shop and they re-did it at no charge (and threw in a car wash). The mechanic told me the belt must have slipped one notch when they were putting it through the tensioner.
It was close enough that I would never have noticed the error based on the car’s performance if it didn’t throw the CEL.
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
