Mainiflod Absolute Pressure Sensor...P0107 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 10-08-2008, 11:07 AM   #1 (permalink)
View Mytman's Photo Gallery
Hi All
Just got this code from my wife's car P0107. I checked it out and it is MAP sensor bank 1 lean. Where is it? Please help.
Any help will be greatly appreciated.
ML
Mytman is offline   Reply With Quote
Old 10-08-2008, 11:29 AM   #2 (permalink)
just a nobody
MAP? I don't believe the Avalon has a MAP, a MAF maybe? The MAF is the one that is mounted on top of the air cleaner housing. And what is P0107? Don't believe there is such a code either, P0171, which is a lean fuel system code?
N.E.O.
Old 10-08-2008, 11:47 AM   #3 (permalink)
P0107...
Just to sure... I went outside to check it and it's P0107. I have 2000 XLS Avalon (wife's). I also went to the web and type P0107 and it came back with Manifold Absolute pressure/barometric something... sensor. I understand there is a Mass Air Flow (MAF).
Thanks
Mytman
Old 10-08-2008, 01:45 PM   #4 (permalink)
just a nobody
How do you check the code? P0107 is definitely not a code that Toyota use.
N.E.O.
Old 10-09-2008, 04:51 PM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
Does the car stumble at idle or have a dead spot when you hit the gas? Are you using a K+N oiled filter?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-16-2008, 05:42 PM   #6 (permalink)
NEZ
View NEZ's Photo Gallery
P0107 is a code (MAP/Barometric Pressure Circuit LOw Input) but does not pertain to any U.S. spec Toyota vehicle if its the P0171 then you need to replace the air fuel meter part#22204-07010.
NEZ is offline   Reply With Quote
