Multiple Problems in Avalon 2003 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 10-28-2008, 12:22 AM   #1 (permalink)
View manishkukreja's Photo Gallery
Hello All
Just had 90k schedule maintenance on my 2003 avalon, after the visual inspectin and test drive the technician has recommended repairs as car pulls left, Steering Wheels Off and Noise over bumps, would like to have your views on them.
1. Timing Belts , Drive Belts, Rear Engine Mount and Bolt- 520$
2. Lower Control Arm Bushing have started to peel off- 900$
3. Rear Sway Arm Bushings-145$
4 Wheel Alignment-90$
MSK
Woburn,Mass
manishkukreja is offline   Reply With Quote
Old 10-28-2008, 01:22 AM   #2 (permalink)
just a nobody
The timing belt you should probably have done at 90k, and maybe the belts too, since there would be additional labor.
What is the reason for the rear engine mount replacement? And the bolt?
Are you experiencing any of the symptoms that he was talking about? If not, I would suggest getting second opinion.
N.E.O.
Old 10-28-2008, 09:28 AM   #3 (permalink)
Hi N.E.O
I am expericing all the problems mentioned.
I would like to know if the mentioned problems can be seviced by a non toyota dealer ..like MIDAS or Meinke are they worth trying?
Or should i trya different toyota dealer even for a second opinion.
Thanks
MSK
Old 10-28-2008, 11:15 AM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
Originally Posted by manishkukreja View Post
Hello All
MSK
Woburn,Mass
It's not that the prices quoted are outrageously expensive, but there's room to scrutinize the potential bill. I'd ask for a breakdown on price for each repair, and then compare them to the Chilton manual. For a quick example, is the wheel alignment for the front axle only, or is that a four wheel alignment? Just food for thought...always be wary of ANY dealerships or local repair shop costs.
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 10-28-2008, 08:54 PM   #5 (permalink)
just a nobody
I personally wouldn't go to Midas or Meinke, for alignment or suspension work. If you are indeed having handling and noise concern, then by all means have the alignment and the sway-bar bushing repair done; however, I am still not sure about why the rear mount and bolt needs to be replaced, and also the control arm bushing. Those are the items I would suggest get more information on. At 90k, your Avalon is not new, but the mileage is not really high enough to experience control arm bushing problem, unless there were external damage or been in accident previously.
N.E.O.
Old 10-29-2008, 11:05 AM   #6 (permalink)
View ChiTDI's Photo Gallery
You could go to a frame/front end shop and get a second opinion. Those front end issues are not common in my experience. TB@90k for sure. Not necessarily at a dealer, though. Perhaps you could package the repairs, save some bucks.
ChiTDI is offline   Reply With Quote
Old 10-31-2008, 03:56 PM   #7 (permalink)
View boblee's Photo Gallery
Australia
Our Avalon 2002 (140K) has had to have two wheel alignments but would be seriously questioning most of the other stuff especially at only 90k unless you have been doing an awful lot of dirt road driving (which we do).
We have had no problems yet except tyres, wiper blades and a couple of windscreens.
boblee is offline   Reply With Quote
Old 10-31-2008, 04:20 PM   #8 (permalink)
View aznstylez's Photo Gallery
Damn!!! $90 bucks for alignment? What kinda Toyota Dealership is it, performance? Our Toyota Dealership cost only $60. Thats a good deal to change the Timing Belts , Drive Belts, Rear Engine Mount and Bolt, make sure they check the timing afterwards though. That is very expansive to replace the Lower Control Arm Bushing have started to peel off. Should try out an independant mechanic.
aznstylez is offline   Reply With Quote
Old 11-04-2008, 11:05 AM   #9 (permalink)
Did that TB job include a water pump? Might want to reconsider.
Old 11-04-2008, 11:46 AM   #10 (permalink)
Do you feel lucky?
TrailDust's Avatar
That's exactly why I recommend checking the Chilton guide first to get an idea on price for any repair. I had a dealership do that to me with an Acura Legend I once owned. They replaced the timing belt, but in the billing charged me for removing the water pump (among other bogus charges), which is a charge included in the timing belt repair. They didn't want to refund me the money, and all it took to get it back was to threaten to report them to the state attorney general's office...BAM!, instant refund. You got to keep an eye on repair facilities or you can get burned.
TrailDust
2002 Avalon XL
Old 12-15-2011, 02:25 PM   #11 (permalink)
View iluvavalons's Photo Gallery
I went to Meineke and the told me I needed struts etc, etc. I went to toyota dealer with the diagnosis sheets and I didn't need struts or any of the other things they said I needed. So beware.
iluvavalons is offline   Reply With Quote
Old 12-15-2011, 04:21 PM   #12 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
The charge for the rear sway bushing change is crazy. The Toyota parts list for $12.75 each side, and I can do them in my driveway in about 15 min each side.
The bushings for the front list for about $50 per side, so $800 labor? Outrageous.
TedL is offline   Reply With Quote
