Have looked at the wiring diagram for 2002 USA Camry.
The alt has a built-in regulator.
There is a wire going to the Body ECU BUT it comes off the wiring running from the alt to the charge indicator dash light.
Are the wire colors: Black (large wire to battery -B), White (goes to Alt-S fuse-S), Yellow/Green (goes to charge indicator light AND ECU input-L) and Red/Purple (goes to Gauge fuse-IG).
Check the back of the alt case for stud terminals labeled B, S, L and IG. These terminals correspond to the wires above -B, -S, -L, etc.
The alt appears to be typically of those used in USA cars. The ECU connection again is just wire running from the charge indicter light circuit to the ECU. A Yellow/Green wire connecting to terminal 18 of the ECU. Do not see how this wiring could control alt output but could be used to monitor if the alt system is charging.
