02 Avalon EFI relay - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 10-30-2008, 10:27 PM   #1 (permalink)
View Trooper76's Photo Gallery
02 Avalon EFI relay
About a month ago, I washed my 02 Avalon XLS. After the wash job I noticed a clicking sound coming from under the hood. I found that the noise was the EFI relay. When I drove the car that same evening the abs light was flashing and the vsc and vsc off lights were on. The abs light went off after a semi-hard braking. All of these problems seem to be intermittent. The EFI relay only clicks when the key is out of the ignition. I took the car to O'Rielly's for a code read. They said there were no codes. I talked to a local dealer and they told me that O'Reilly's could only read carb?? codes. The guy at the dealership told me that they had a Lexus come in with the clicking relay problem and they unplugged the door chime and the problem went away. After spending an afternoon standing on my head, I found the door chime and unplugged it, after that the relay would click with the key in and out of the ignition. I'm not a mechanic, but I'm pretty handy. Can anybody shed some light on this or point me in the direction I need to go? Thanks
Trooper76 is offline   Reply With Quote
Old 10-31-2008, 01:26 AM   #2 (permalink)
just a nobody
It may be the key reminder contact in your ignition lock cylinder housing shorting out and feeding power to the EFI relay. You can locate and unplug the switch and see if it still make the noise.
N.E.O.
Old 10-31-2008, 10:40 PM   #3 (permalink)
I think that's what I unplugged that caused it to do it key in or out. I called it the door chime. Oops
Old 10-31-2008, 11:10 PM   #4 (permalink)
just a nobody
What colors are the wires for the connector you had unplugged? The one I was referring to should have a red wire with a yellow tracer, and white with a black tracer.
N.E.O.
Old 11-02-2008, 06:57 PM   #5 (permalink)
Thanks for the info, I'll check and see.
Old 01-26-2010, 09:17 PM   #6 (permalink)
View runco0318's Photo Gallery
Whatever happened with this post? My 00 Avalon has the exact same symptions, but I did not wash the car. I have clicking EFI relay after the ignition switch is off, key is out. ABS light was blinking. Both issues happened at the same time.
runco0318 is offline   Reply With Quote
Old 02-27-2010, 07:42 PM   #7 (permalink)
I wanted to update everyone. After scouring Toyota Nation and other Googling endlessly, I have finally pinpointed my problem and fixed my problem. I replaced both the ignition switch ~$79 and the switch assy, unlock or key sense switch ~$21. I am sure it was the ~$21 part, but I didn't want to take any chances since I had disassembled my dash to get to the ignition switch. I didn't have to remove the ignition switch assy, it was a tight fit to work, the air duct was in the way, but I managed. I am proud to report my problem is now fixed. So no more clicking, no more draining batteries.
Old 11-09-2010, 09:49 PM   #8 (permalink)
View wood234's Photo Gallery
ABS light has been flashing, then stays on for a while, then off, intermittently for a couple of months on my 2000 Avalon XLS with no codes. After having the steering column recall work done by a Toyota dealership a couple of weeks ago, now additionally have intermittent relay clicking when the key is out of the ignition, and also intermittent door chiming when the door is open but the car has been turned off and the key is out of the ignition. Two Toyota dealerships, after charging me $105 each for an hours worth of diagnostics, tell me that they would probably need extensive time to find problem. They tell me that it is just best to purchase another vehicle! They have also told me that my ignition switch is fine and the problems have nothing to do with the steering column recall work done. Help if you can. Thanks
wood234 is offline   Reply With Quote
Old 11-10-2010, 06:43 PM   #9 (permalink)
I highly recommend the key sense switch ~$21. You can fix yourself in <10 minutes. If this does not work, then make the decision about the ignition switch or their suggestion. The ignition switch is slightly more difficult due to the air duct in the way, but I was able to tackle it in less than an hour. Good luck.
Old 11-19-2010, 02:09 PM   #10 (permalink)
View uscgrad91's Photo Gallery
Do you have a part number for the key sensor switch? I called my local dealer and the parts guy says there is no such part. He sent me a key inter(?) solenoid switch ~$73. Part # 8543233020 Thx.
uscgrad91 is offline   Reply With Quote
Old 11-19-2010, 11:20 PM   #11 (permalink)
Try this one, not 100%, but your dealer will know, and will guide your dealer:
SWITCH ASSY, UNLOCK
Part #84052-12070
SWITCH ASSY- UNLOCK
The Following User Says Thank You to runco0318 For This Useful Post:
uscgrad91 (11-20-2010)
Old 01-06-2012, 02:31 PM   #12 (permalink)
View chris_Star1591's Photo Gallery
Please help
Hi, I have the same problem with my Avalon'00. during rain season, the ticker noise started coming from EFI relay when the key is out. The abs light is on and power windows button on the driver side stops working along with the door lock unlock button.
pls can you help how to change the key sense switch. I tried it but could not find my way
chris_Star1591 is offline   Reply With Quote
