2002 Avalon XLS Passenger heat vents blow cold - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-01-2008, 11:00 PM   #1 (permalink)
View kperry88's Photo Gallery
The driver's vent and defrost are hot. The passenger are cool. It's not in dual or auto mode. Have turned it off completely, back on, tried many combinations, etc.
Any help is appreciated. Will take a closer look in the morning when I have daylight.
kperry88 is offline   Reply With Quote
Old 11-01-2008, 11:43 PM   #2 (permalink)
View aznstylez's Photo Gallery
Is your A/C operated by turning the knobs(cable driven) or push of a button(electric)? If it is cable driven, rip out the carpet on the driver's side where the gas pedal is, check to see if the end of the cable that is connected to the manual control of the knobs is still connected to a white plastic piece(the white piece can be push back and forth).
aznstylez is offline   Reply With Quote
Old 11-02-2008, 12:20 AM   #3 (permalink)
just a nobody
Maybe the passenger side air mix damper actuator having problem.
N.E.O.
Old 11-02-2008, 06:18 AM   #4 (permalink)
It's all push button. Seems like I need to find a repair manual to see what and where the parts are.
Old 11-02-2008, 02:25 PM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
If you're not aware of it, for a fee you can access Toyota's Technical Information System to get the information you need. Here's the link....
https://techinfo.toyota.com/techInfo....toyota.com%2F
Good luck....
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
