Even pitch tone from rear, 2001 XL - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-02-2008, 04:38 PM   #1 (permalink)
View Marylandmann's Photo Gallery
USA Even pitch tone from rear, 2001 XL
I love my 2001 Avalon XL! With 135,000 miles on it, it has never been a moment's problem! Best car I have ever had...
A problem has, however, arisen. Seemingly from the rear somewhere, there is an even-pitched hum (maybe G-flat above middle C). It never occurs when accelerating or braking. When it does occur, I am driving at a constant speed. The hum does not change pitch under any circumstances, at least not yet.
I can also make it happen in idle and in gear with the brakes applied. But only over a very narrow range of pressure on the accelerator.
It does not start happening until I have driven several miles.
Any thoughts?
Thanks,
Dave
Marylandmann is offline   Reply With Quote
Old 11-02-2008, 06:47 PM   #2 (permalink)
just a nobody
Fuel pump maybe? But they are usually a 'D' flat.
Just kidding, that is about the only part in the back of the car that would cause a humming sound beside the exhaust. The fuel tank is under the rear seat, have someone drive the car while you ride in the back and see if the sound is emitting from that area.
N.E.O.
Old 11-03-2008, 04:25 AM   #3 (permalink)
USA It's odd...
I had a buddy sit in the back seat. He is a big guy, maybe 280#. The sound did not occur at all. Same when he was in the front seat.
But when a much smaller person (120#) is in the car, the intermittent tone is heard as described. Well, maybe I am tone deaf and it is a D-flat!
Where is the fuel pump? In the gas tank (groan)? Which side of the car?
Thanks!
Dave
Old 11-03-2008, 07:05 AM   #4 (permalink)
just a nobody
Left side of the rear seat cushion.
N.E.O.
Old 11-03-2008, 07:44 AM   #5 (permalink)
Avalon rear hum
Thanks very much NEO!
Is it accessed by removing the rear seat, or must one drop the fuel tank and pay astonishing labor?
I have replaced fuel pumps myself, but only when years ago they were easy to deal with.
Old 11-03-2008, 09:15 AM   #6 (permalink)
just a nobody
It is accessible from the inside of the car after you have remove the seat cushion and the cover plate; Just grab hold of the front edge of the rear seat cushion and give it a firm tuck; the plate that cover the sending unit/fuel pump assembly should be visible. You may, however, want to read up on it a little bit before doing anything.
N.E.O.
Old 11-03-2008, 03:32 PM   #7 (permalink)
USA Online Literature?
Does anyone know online locations where I can research this and other servicing issues for the 2001 Avalon? I cannot really afford to buy the various books that are for sale.
Old 11-03-2008, 03:51 PM   #8 (permalink)
just a nobody
The Camry V6 of the same year should be the same if you are not able to find a manual for the Avalon.
N.E.O.
Old 11-03-2008, 03:57 PM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
You can access Toyota's Technical Information System on a pay-for-use basis, which is not expensive. Check it out at this link:
https://techinfo.toyota.com/techInfo....toyota.com%2F
Good luck.
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
