Relay draining my battery - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-07-2008, 06:41 PM   #1 (permalink)
View rugsucka's Photo Gallery
Canada Relay draining my battery
My uncle has a 2002 Avalon - not sure of the package, but he is having an issue with a relay that sometimes clicks after shutting the engine offl.
This doesn't happen every time, but it has been runnning the battery down.
Toyota can not seem to find the problem.
What he does do is pull the relay at night to get around this.
I will get more info from him re: where it's located, but is there any known issues to drive straight to the problem?
Thank you for your effort - I know I just registered specifically for this question but do drive a '03 Toyota Vibe (lol)
rugsucka is offline   Reply With Quote
Old 11-07-2008, 07:15 PM   #2 (permalink)
View toyomoho's Photo Gallery
Find out what the name of the relay, the relay box should have a label.
Old 11-07-2008, 08:21 PM   #3 (permalink)
View ChowChilla's Photo Gallery
Replace the relay , there might be an internal fault in it and it sticks at times, and if pulling it take care of the issue....well there a good chance that the fix
Chow
92 Diaminate
96 Cherokee
01 Avalon
06 2500 Silverado
ChowChilla is offline   Reply With Quote
Old 11-07-2008, 08:39 PM   #4 (permalink)
just a nobody
Probably the EFI relay, maybe? If that is the relay, check the unlock warning switch for the ignition lock cylinder.
Toyota 'Vibe'? Thought that was a Pontiac!
N.E.O.
Old 11-09-2008, 08:05 AM   #5 (permalink)
I will talk to my uncle today and pass on the advice - If it's so simple as to just replace the relay, I don't know why the stealership hasn't already - but the ignition lock cylinder sounds a little more obscure.
and New eCHo - I call my vibe a toyota because it is everywhere it counts - and having driven an AWD Matrix before this 5 spd, if it weren't for the triangle in the steering wheel you wouldn't know the difference.
Old 11-09-2008, 08:16 AM   #6 (permalink)
just a nobody
It isn't the relay that is bad, it is what is causing the relay to stay on that is the difficulty in resolving the problem.
I was just teasing you about the 'Vibe', it is after all make mostly by Toyota.
N.E.O.
Old 01-26-2010, 08:53 PM   #7 (permalink)
View runco0318's Photo Gallery
Whatever become of this problem. My 2000 xls is doing the same thing with the EFI relay. What is the solution?
runco0318 is offline   Reply With Quote
Old 02-27-2010, 07:43 PM   #8 (permalink)
I wanted to update everyone. After scouring Toyota Nation and other Googling endlessly, I have finally pinpointed my problem and fixed my problem. I replaced both the ignition switch ~$79 and the switch assy, unlock or key sense switch ~$21. I am sure it was the ~$21 part, but I didn't want to take any chances since I had disassembled my dash to get to the ignition switch. I didn't have to remove the ignition switch assy, it was a tight fit to work, the air duct was in the way, but I managed. I am proud to report my problem is now fixed. So no more clicking, no more draining batteries.
