Should I Replace My Water Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-11-2008, 03:33 PM   #1 (permalink)
View RSVESL9's Photo Gallery
I'm about to change the timing belt ( 169,000 ) for the 2nd time on my 2000 Avalon XL. The water pump has never been changed and I have not had any problems with it. Do you think it is a good time to replace the water pump since I'm changing the timing belt? Thanks
RSVESL9 is offline   Reply With Quote
Old 11-11-2008, 04:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
It's a gamble. You are beating the water pump will not fail in the next 90K miles (assuming you still own the car).
Typically owners follow this procedure and would change it now. Still there has not been a rash of pump failures reported.
If doing the work yourself an after market pump is pretty reasonable $$ wise, plus idler bearings. Also check the cam and crank/oil pump seals for leaking.
Old 11-11-2008, 04:42 PM   #3 (permalink)
O.O
View O.O's Photo Gallery
Since you are changing the timing belt, it is a wise decision to replace the water pump as well since it is recommended. You would want to do preventative maintenance on it since once it fails it will cost you more for repairs.
O.O is offline   Reply With Quote
Old 11-11-2008, 05:35 PM   #4 (permalink)
NEZ
View NEZ's Photo Gallery
I would change pump cause in the event it does start leaking you might have to replace the t-belt again I would also look into changing the front seals while your in there
NEZ is offline   Reply With Quote
Old 11-13-2008, 12:37 PM   #5 (permalink)
View ChiTDI's Photo Gallery
Good time?
Yes. If the water pump goes the coolant ruins the belt and you have to replace that if it doesn't break first.
Cam seals too if it were me.
ChiTDI is offline   Reply With Quote
Old 11-13-2008, 04:53 PM   #6 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
I'd have to go along with changing it out now. Given you've gotten 169,000 already, it's problematical that the pump may fail sooner rather than later. This is one of those situations where you'll save grief and money in the long run by doing it now. Go for it!
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-13-2008, 07:06 PM   #7 (permalink)
Thanks, I am going to replace the water pump as well as the timing belt. I appreciate everyone's input.
