Rear Suspension Banging - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-15-2008, 10:56 PM   #1 (permalink)
View Boston Fireguy's Photo Gallery
USA Rear Suspension Banging
The rear suspension (especially the right side) on my '04 XLS has been banging over bumps for awhile and occassionally bottoming out with rear passengers. Mileage is 75K. I've done the bump test and the struts still have a good amount of resistance. Is it time for struts, mounts or both?
Has anyone come across a heavier rear coil spring that will fit?
Boston Fireguy is offline   Reply With Quote
Old 11-19-2008, 05:48 PM   #2 (permalink)
View toyomoho's Photo Gallery
Banging noises can be caused by the upper strut mounts, sway bar bushings, sway bar end links.
The upper strut mounts area located on the outer side of rear deck speakers. Listen in this area as the car is being driven over bumps.
The struts themselves rarely make this type of noise.
Old 11-25-2008, 10:05 AM   #3 (permalink)
View shocar4's Photo Gallery
replace your bushing on your rear sway bar......almost a guarantee that will solve your problem.....just did this myself on my 03.....cost me $20 from the dealer and it took me less that 30 minutes!
1999 SC'ed DWP Solara 5spd!!!
shocar4 is offline   Reply With Quote
Old 11-25-2008, 03:20 PM   #4 (permalink)
USA
Thanks, Shocar4. I'm hoping it's omething like that. I'll let everyone know when I get it up on the lift.
Old 11-25-2008, 07:35 PM   #5 (permalink)
The Connoisseur
CharmCityES's Avatar
check your upper strut mounts and rear sway bar busings....almost all older avalons have this noise when either of these go up
im fairly sure that at that milage the struts and mounts should be OK, and its most likely the rear sway bar busings since theyre the first to fail.
The "Executive Sedan"
Old 12-12-2008, 03:39 AM   #6 (permalink)
Banned
View Florian 123's Photo Gallery
I repaired the Bushings, the are split, I clued in a piece of rubber from a car inner-tube, which is about 2mm thick, this takes care of the wear of the stabilizer bar and Bushing, no need to change the Bar, took me 1 Hour no cost, the two screws that hold the bushing can easily be removed as long as the are not rusted. No need to remove any links, just jack up the car in the rear on both sides it took care of the noisy from suspension.
John in Montreal
Florian 123 is offline   Reply With Quote
