Originally Posted by John Francis
I am the original owner of 2000 Avalon XLS and only recently have begun to experience water in the trunk which settles into the wheel well after HEAVY RAIN. I just had it at the Toyota dealer's for service and they were not able to determine the source of the leak even after they ran water on the car with no luck in determining the cause of the water getting into the trunk. ANY SUGGESTIONS?
Thank you. John
I got hit in a parking lot a few years back which resulted in a slight warping of the trunk, allowing water to leak from the seal by the rear window and run down the sides of the trunk and gave the appearance of a leak in the bottom. When I had the warping repaired, the tech also said bad seals would produce the same affect. This may seem a dumb question, but have you thoroughly inspected all the seals? Leaks can be tricky, and originate where you least expect them.
TrailDust
