Originally Posted by toyomoho
The mirror may be glued onto the holder with hot melt glue. Some folks stated they had a window and mirror shop replace it or might call an auto window shop.
Thank-you for your advice.
My windshield and mirror repair guy tells me I have to replace the entire assembly. He says it's impossible to remove the mirror from the housing.
I can adjust the mirror and see behind it. There are modular plugs that had to be connected after the mirror was fitted into the housing. There's got to be a way to remove the
mirror only from this housing without removing the entire assembly from the door.
The estimated cost for OEM replacement of the entire assembly and labor is +/- $300. I'd sure like to find a way just to replace the mirror
or mirror and holder without replacing the entire assembly. It's just such a waste!
Thanks again,
hudlow
