RSB Sway Bars? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 11-27-2008, 01:38 PM   #1 (permalink)
View aznstylez's Photo Gallery
RSB Sway Bars?
Does anyone know of a rear aftermarket sway bar that would fit 2000-2004 Avalons? Would the rear sway bars for the 97-2001/2002-2006 Camrys fit?
aznstylez is offline   Reply With Quote
Old 12-12-2008, 03:35 AM   #2 (permalink)
Banned
View Florian 123's Photo Gallery
No need to change the Sway bar if only the noise is the problem.I repaired the Bushings, the are split, I clued in a piece of rubber from a car inner-tube, which is about 2mm thick, this takes care of the wear of the stabilizer bar and Bushing, no need to change the Bar, took me 1 Hour no cost, the two screws that hold the bushing can easily be removed as long as the are not rusted. No need to remove any links, just jack up the car in the rear on both sides it took care of the noisy from suspension.
John in Montreal
Florian 123 is offline   Reply With Quote
