2002 Avalon Front End Rattle - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 12-11-2008, 09:10 PM   #1 (permalink)
View Golfduff's Photo Gallery
I have a rattling sound that sounds like it is coming from the passenger side inner fender. I can hear from the inside of the car while driving especially when I hit a bump, it almost sounds like a loose shock/strut, but I checked and appears that everything is intact. any suggestions?
Thanks
Golfduff is offline   Reply With Quote
Old 12-11-2008, 10:31 PM   #2 (permalink)
just a nobody
Upper strut mount will cause noise like a rattle can when you hit a bump.
N.E.O.
Old 01-09-2009, 02:50 PM   #3 (permalink)
View joebob452's Photo Gallery
It is a common problem on any car w/struts for the mounts to start to seperate between 100k - 150k on the front and 200k - 250k on the rear depending on driving habits. However, you can't just take it in and have the struts changed because they normally don't change the mounts(bearings). I have also noticed a big difference in other cars when I also changed the coil springs. Now I change everything when my struts start to go bad.
joebob452 is offline   Reply With Quote
