Timing belt/ water pump question
Hi all,
I bought a used Avalon w/ 115k miles on it and am changing the timing belt. Bought tensioner, tensioner bearing, idler bearing, water pump and belt from the dealer. Had a heck of a time taking off the two brackets on the back of the plenum(upper intake) so I could get to the spark plugs.
When I looked at the water pump the Hanes manual says to take both Camshaft sprockets off so that the metal shield, that covers part of the water pump, can be taken off. The left cam sprocket is burried so I can't get my impact wrench anywhere near it. I tried using a big strap wrench to keep it from turning, but it is on so tight it won't work.
So my questions are these:
1) my old car was a Corola with 300k on it and I never changed the pump on it. (Bought it w/20k on it) Everytime I went to change the timing belt, the pulley had no play and didn't make any noise. So should I even worry about going through all the trouble of changing the water pump on my Avalon?
2) I know on most cars after you take the valve cover off there is a spot at the end of the camshaft to grab it with a big open ended wrench. Is there a special tool that fits into the limited space in front of the cam shaft that will be able to hold it, or do I have to take the valve cover off?
3) The car didn't come with a remote or a spare key. I bought a factory remote, but the instructions I got from an internet site didn't work at all. Any instructions for programming a remote or a new transponder key would be appreciated.
thanks ahead of time for any help,
Joe
