Car Turning off ABS/BRAKE??? Please Help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-13-2009, 11:12 PM   #1 (permalink)
View avlon00's Photo Gallery
Unhappy Car Turning off ABS/BRAKE??? Please Help
My girlfriends 2000 avalon is turning off while turning, the car shuts off and the abs and brake light turn off...the car recently ran over a log while on the freeway. Is it possible the abs sensor got damaged? Causing the car to turn off while making turns? please help!!!
avlon00 is offline   Reply With Quote
Old 01-14-2009, 07:04 PM   #2 (permalink)
View shortrun's Photo Gallery
Step 1. Check the brake fluid.
Just to be clear, the "Brake" warning light comes on when going around a corner?
The engine shut's off while going around a corner?
Both right and left corners? If going really slow around the corner, same problem?
Sorry for no answer, just more details required.
shortrun is offline   Reply With Quote
Old 01-15-2009, 12:08 PM   #3 (permalink)
View joebob452's Photo Gallery
Sounds like the lights are only on because the car shut off, but the ignition is still on?
I would have a shop put it up in the air to look for possible body damage from running over the log. Sounds like its shutting off on turns because the wheels are hitting something on sharp turns.
joebob452 is offline   Reply With Quote
Old 01-20-2009, 03:09 AM   #4 (permalink)
sorry about the details...the car would shut off, if you made right turns, bizare just a few days ago the cars battery caught on fire???? I am baffled!!!! i have no idea, why that happend. Loose connectors? Defective battery?
how can i roll the window up, without any power? Thanks for any help
