2000 XLS arctic cold starting question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-15-2009, 12:34 PM   #1 (permalink)
View kegunder's Photo Gallery
My Avalon did an odd thing when starting this morning at -18 degrees F. Most things that happen at that temperature are surprising (at least to us Iowans), but perhaps the Avalon was behaving as designed.
When engaging the starter, my first reaction was, "The battery is WAY to weak." It took about a full second for the crankshaft to turn one rev. Then two things happened at the same time. First the engine sprang to life, and idled perfectly. Second, the dash went totally dark, even the tach. Ten seconds (or so) later the everything was back to normal and the car has run perfectly. The dash clock reset itself though.
Can anyone explain if this was a sign of a low temp. ground fault or something like that?
Thanks!
kegunder is offline   Reply With Quote
Old 01-15-2009, 02:11 PM   #2 (permalink)
View toyomoho's Photo Gallery
Clock memory is powered by Dome fuse that gets power directly from battery.
Dash lights are controlled by Tail light relay via the light switch.
Check battery cables and terminals. Bad wire connections can cause strange problems.
Old 01-19-2009, 03:44 PM   #3 (permalink)
tr7driver's Avatar
View tr7driver's Photo Gallery
FWIW It was -23 here last week an my 2000 avy just cranked right up as usual. Gotta love the midwest weather.
Thanks!
2000 Avalon XLS
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
1998 Avalon XLS 'RIP' (gave its life for us!)
1994 Honda Accord Wagon, 1979 Triumph TR7
tr7driver is offline   Reply With Quote
Old 03-05-2009, 12:58 PM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
A block heater can always help, if you can plug it in. When i lived in Maine I used quick connect battery clamps and took my battery into the house. (no garage) I also used a block heater. The temps would drop from -65 to -100 below. Gee I miss that place.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
