01 Avalon Rack&Pinion slop - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 01-24-2009, 11:34 AM   #1 (permalink)
View Jrica945's Photo Gallery
USA 01 Avalon Rack&Pinion slop
On my '01 Avalon (136K miles) the right side of the rack has slop. When I grab the right tire at 9 & 3 o'clock position it moves about 1/4" to 1/2". The left side is tight. System is good otherwise, no leaks. Balljoints & tierods are good. Is replacing the rack & pinion assembly the only option? Is it safeto drive like this?
Jrica945 is offline   Reply With Quote
Old 01-24-2009, 01:26 PM   #2 (permalink)
View toyomoho's Photo Gallery
Is this up and down play or axial movement?
Did you check the inner tie rod joint that is under the steering housing boot for play?
Old 01-24-2009, 03:24 PM   #3 (permalink)
It is axial. I removed the tie rod from the tire and there's play in the rack (by pushing in & out) at this point the play is about 1/8" or 1/4". There is no play on the left side.
Old 01-26-2009, 09:33 AM   #4 (permalink)
View kegunder's Photo Gallery
Everything that I've heard about steering slop would indicate that your car is not safe. Driving in traffic at any speed is not advised until your issue is diagnosed or fixed.
Perhaps the inner tie rod has worn out behind the bellows.
kegunder is offline   Reply With Quote
Old 01-26-2009, 09:43 AM   #5 (permalink)
just a nobody
With 136k miles might consider replacing the complete rack and pinion assembly, even though you can replace the tie-rod by itself.
N.E.O.
