thermostat housing? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 07-10-2009, 03:29 PM   #1 (permalink)
View Darkstar187's Photo Gallery
thermostat housing?
Hey guys can someone please point me in the right direction of the thermostat housing? my guess would be on the drivers side following the rad house back? do i need anything else besides the thermostat and the rubber gasket that goes around it?
thanks you very much!
Billy
Darkstar187 is offline   Reply With Quote
Old 07-10-2009, 07:31 PM   #2 (permalink)
View 05DCLB's Photo Gallery
Correct, stat is on trans side of engine. Get a Toyota stat and coolant, dont mix red with green.
05DCLB is offline   Reply With Quote
Old 03-02-2010, 11:17 AM   #3 (permalink)
View tommybwart's Photo Gallery
why the dealer thermostat.. aren't the aftermarket ones decent enough ?? and what IS the deal with the red versus the green coolant? is the red proprietary or something ? and is there REALLY a diffrence ?
thanks
tommybwart is offline   Reply With Quote
Old 03-02-2010, 01:44 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
thanks
Yes.
Toyota Red uses a phosphate anti-corrosion chemistry. The green uses silicates. Both are inorganic chemistries, but they are incompatible. Phosphates do especially well with iron, and do fine with aluminum, and with copper/brass/lead radiators and heater cores. Japanese auto makers prefer phosphates.
Silicates like Prestone green are particularly good with aluminum, not as good with iron, and do fine with copper/brass/lead. They are slightly abrasive, and are slightly more likely than phosphates to cause leaks in water pump seals. European auto makers prefer silicates. Oh, and never mix the red and green.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
