AC - Belt Noise or Compressor Clutch? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > 2nd Generation (2000-2004)
2nd Generation (2000-2004) Specific discussion of the second generation Toyota Avalon
Old 07-11-2009, 10:16 PM   #1 (permalink)
View ricknh's Photo Gallery
I have a real noisy squeal when I first start the car if the a/c is on. It goes away if I turn the a/c off, or after a couple of seconds/minutes. Also, if I open the hood and listen closely, I hear a rattle (or knocking) when the system cycles (after the squeal goes away). I tried a belt dressing, but that made the squeal much worse for a bit. Is it more likely the belt, the a/c compressor clutch, or...? As luck would have it, I have 2 weeks BEFORE my extended warranty expires. Anyone got a guess where to look? Thanks in advance... Details: Avalon 2002, XLS, 87K miles, otherwise in pretty good shape.
Rick
ricknh is offline   Reply With Quote
Old 09-02-2009, 02:27 PM   #2 (permalink)
View galingula's Photo Gallery
Rick
I have the same issue and was recently told by a guy at Uncle Ed's that it was the clutch. He looked a the belts when I restarted with the AC cranked I was able to reproduce the noise, and he looked and told me it was the clutch
galingula is offline   Reply With Quote
Old 09-02-2009, 10:16 PM   #3 (permalink)
Thanks for the update. I suspect the clutch as well. So far, if I start with the a/c off, then wait just for 30 sec. or so, the crank up the fan speed slowly, I can get the a/c running with minimal or no squeal. All is fine after that, but I think I'll look into it sooner rather than later.
Old 09-02-2009, 11:25 PM   #4 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
Gen1
Yea I have been having that same problem lately, tried belt dressing but that almost made the belt slip off
pmesfun is offline   Reply With Quote
Old 09-03-2009, 07:29 AM   #5 (permalink)
I turn the fan down a bit and then gun the gas a couple of times, and that usually fixes it.
Does anyone know if the clutch can be replaced seperatly from the compressor?
Old 10-05-2009, 05:51 PM   #6 (permalink)
View bowlinm's Photo Gallery
I too suspected the A.C. clutch. It was also time for belt replacements. I replaced both belts and NO MORE SQUEAK. I was also surprised at how much more quiet the car was at idle w/o the air on also.
Matt
bowlinm is offline   Reply With Quote
